- Oct 15, 2008
- wme451 a124 r129 s211 r230
I've just changed the spark plugs on my 96 E280T (along with some other work), which was "serviced" just before I bought it late last year.
The problem I had was after running on a journey for an hour or so, the engine would slightly misfire at higher revs when overtaking, with the odd backfire when kicking down to overtake, but not all the time. Otherwise, the car drove beautifully, with a quiet, smooth tickover. No fault codes showed up after a Star check at my local indie.
I removed NGK plugs (which looked okay), and replaced them with Bosch (plus an air filter etc), and the difference is amazing. Pulling away is much more repsonsive, but I will have to wait until Thursday before I do a long journey (to Le Mans - anyone else?) to see if the misfire has been cured.
One question arises from this, in that when stationary, in drive and on an uphill slope, the car would roll backwards (prior to changing the plugs, and unlike my other MBs). Since the change, it now remains stationary (as do the others). I'm wondering how the technicalities work to explain this? I used to have a DS23 Citroen Safari, with a semi automatic box, and the smooth gear change was totally dependant on the carburettor and tickover being perfectly set up. Is it the same here (not the carburettor bit!)?
