coneybiller
I’ve got an electrical gremlin in my car at the moment! Which is causing me to disconnect the battery when I get to work and when I get home and loosing all of my radio settings each time
When I switch the ignition off and remove the key, the head unit stays on, along with the cigarette lighter socket (I’ve got a phone cradle plugged in with a volt meter in it which stays illuminated). I’ve noticed also that all windows still work and the elec seats also still have power, even with the door open. If I then switch the front wiper on, everything else goes off and the wiper will barely move and causes a relay behind the fuse box to go crazy. The SRS light is also starting to come on. Everything functions perfectly when the engine is running.
Now my battery is pretty shot and I’m thinking of replacing this anyway due to it sitting between 10.5 and 11v without the engine running (I do 150miles a day in this car, so it gets plenty of charge!!) and ~14.4v with the engine running.
I feel like this could possibly be a relay issue, but not sure which relay does what! I removed what I believed to be the N10 relay(which I read feeds the wipers and some other things?) but the wiper still tried to move and it didn’t change the fault at all.
Or could this be down to low voltage, which is not energising a relay enough perhaps?
Arrow points to the relay I removed thinking it’s the N10 relay?
Any ideas?
Regards
Ben
Any ideas?
Regards
Ben
