Apfinfant
Since I been having this problem I had to purchase about three batteries since then first they said it was my alternator so I got that changed still dying then I was told it was a vacuum pump got that changed also car was fine for about 3 days then battery dead again I’ve been doing a little research and from the symptoms listed I believe it’s the rear sam because I recently changed the fuel leveling position sensor and the gauge is still not working but after I changed that it started saying display Defective its says that’s a common thing when the Sam unit is bad the symptoms are taillights not working daytime running lights not working constant battery draining rear sun shade won’t come down and key not working properly.
anyone else having power draining problems
