tjamesbo
- Jan 6, 2007
- Location
- Sutton Coldfield Midlands
- CLK430 ,Vito V6 sport ,Jaguar 2.5 X type ,W124's 1993 220TE , 1994 320TE ,Mastercraft X5
Aftermarket Radio Died on my 1999 CLK this morning on the way home . Its worked satisfactorily for the last 5 years so got home just about to check the fuse when i thought ah is the cig lighter working ? as its common that the permanent live is sourced from there . So after a false start ,where a power feed connector had pulled apart ( i think I did that when removing the radio ) it still failed to turn on I then double checked my remake of the connection to make sure the power was coming through and got 14.1 volts with the engine running I know a few circuits take the typical alternator " charging voltage " but is 14.1 in this acceptable range ? no point connecting another radio unless this is within acceptable tolerance
