I am looking for pointers on where to start with this one. I have a A180 CDI with CVT transmission. The transmission had been working fine except that occasionally, when slowing down and approaching a stop it wasn't quite smooth. It seemed the car still wanted to go forwards and was resisting the brakes to a slightly greater extent than the normal "creep" and then suddenly that would resolve and it would come to a stop normally. I am guessing that maybe was the torque converter lock-up clutch being a little late to disengage.
Now, however, it has a new fault in that it fails to engage drive at all. The engine starts and idles fine and the transmission comes out of park as the car can be pushed, but it will not move under its own power and there is no click of the transmission engaging when selecting 'D' or 'R'. Pressing the accelerator does not cause the engine to rev freely as you might expect in 'N'. There is also no change of engine note as if the engine is trying to overcome something, it is more like the engine management is simply ignoring the accelerator pedal until is quite a way down whereupon there is then a slight increase in revs and then the dashboard shows "Transmission Fault, Visit Workshop" or something along those lines.
This is an 2005 model so I don't want to simply hand it over to someone in exchange for a large bill as that may be more than the car is worth. Is there anything simple to try? I am guessing the transmission has an ECU - how common is the equipment to read codes from it? Any other ideas?
