RAGEisDEAD
Hi All,
Yes I am new to this forum so not sure if this is in the right category but it seems most fitting and I am coming here with my tail between my legs as I have a feeling I have F'd up so to speak, and I'm sure many people wont be able to resist telling me that, and I'm all for it
Anyway... Looking for some help/advice.
I have an A220D 2.0 had DPF issues over the recent months and thrown loads at it, manual regens/ mobile DPF cleaners etc it always came back (and I know its my fault or not taking it on long drives)
Anyway I was recommended to have it removed so I had my DPF "removed" cut off, removed and welded back and EGR deleted and stage 1 remap by a tuning garage they claimed the first time EML came on they had to then welded open the exhaust flaps and map it out.. it then returned (EML) pretty much straight after leaving so he then said it was an error about camshaft sensor, but I wasn't convinced so had it diagnosed by another MB specialist who found codes coming up as P13C271/P13C21E Exhaust flap 1 has malfunction the actuator is blocked and malfunction, resistance value is outside permissible range.
they said to take it back to the tuner and get him to either unweld the flaps and they can have another look or did the tuner forget to map the flaps out of the ECU when welded? IDK
I had so many issues with my DPF I was advised to have all this done and now I'm regretting it as it just one thing after another and the tuner wont take on mechanical work so I am being passed around garages.
I have found an actual MB specialist who sympathize with me who I will be going to moving forward, but at the moment they advised to take it back to the tuners and see what they say but its occupying alot of my time having to taxi around etc.
Would you give the tuners another try to map the flaps out or just get them to un weld them and go elsewhere from here..
Has anyone got experienced with this unethical process of removing the DPF /EGR delete ever had to do anything about the exhaust flaps?
this is the service these guys offer:
"The Diesel Particulate Filter removal involves removing the internals of the actual DPF. Remove existing particulate filter from the vehicle, cut an opening, remove the core, clean and re-seal by welding, Refit back to the vehicle. Then remap the vehicle to remove the regeneration software from the ECU and remove the DPF warning light from the dash."
Any advice would be great
TL;DR had car DPF removed and EGR deleted along with a stage 1 remap, now exhaust flaps code is showing however tuner claims to have welded them open and mapped them out of ECU but MB specialist claims exhaust flaps are causing the fault and i have a diagnostic report to prove that. what do I do?
