No leaks, no ABC warnings but I do seem to feel pot holes more recently. I've been checking my ABC fluid level, it was low, currently I have it at the bottom 'max level when running' which is fine but when I switch off and wait it goes way above the higher 'max level when off'.
So the system is swallowing up more fluid when running than it is meant to. I assume this is a sign of one or more failed accumulators. I can't get my head round why though - if an accumulator fails then eventually the nitrogen will get bled out resulting in increased fluid capacity in the system, but when switched off there will be less or no compressed nitrogen to push the fluid back. So I would expect the on-off range to be narrower with a failed accumulator, not wider???
Anyone with a normal ABC system - is your fluid range 'max level when on' to 'max level when off'? If so can anyone explain why a failed accumulator increases the range (if indeed it does)?
