ABS and ESP fault warning after wheel alignment
alphagemini
Folkestone
Mercedes C200
I have a c200 w203 2006. I had the wheel alignment checked and adjusted. The offside rear wheel was way out of kilter, causing inside edge wear.
Now the ABS and ESP lights show. Is there a reset that overcomes this? Has the computer program gone into a tizzy?
Any help will be gratefully received.
Maybe the ABS sensor wiring got displaced or damaged during the alignment adjusting process?
It's possible the garage has made it worse with the adjustments or if the tracking is good, you'll have to get the steering angle sensor calibrated. Very easy for anyone with a computer. It might be reason 1 why the light is on though. I think its way off now
You could try a few slow lock to locks to reset the steering angle sensor.
