GordonT
2016 220 C class 65000 miles. Ive been through the process of replacing the two Nox sensors and replaced the Adblue injector after a sensor problem a few months ago. Its been working well until I filled up with adblue. Topped it up as was getting low, jumps into car and engine light on and message adblue level cant be read. Damn! Looking through the threads on here, its looking like the dreaded adblue level sensor problem has arose and needs replacing. Milage countdown has started even after a reset with icarsoft reader.
Looking online the level sensor ( A0145428717) is about £75 and can be sourced from a few places.
Now, is it a big job to replace it? Does the adblue tank need to be taken off? Has anyone changed one and found it to work or is it a main dealer job? I can shuffle spanners ok, just need a heads up on a cost effective repair if possible.
Thanks for reading this far. G.
