Alarm keep going of
Carrie01
Hi I have another problem with this car I've changed my battery and ever since then the car alarm keeps going of mainly at night how do I disconnect the alarm it's a ml320 X reg
You can't disconnect the alarm easily at all (it should be battery backed, so if you disconnect the wires the siren will sound)
However, you can turn of the interior motion sensor and the anti tow sensor to see if its one of those.
But, I can't remember how to do that on the ML as its different to others (and changed at the MY02 facelift) - but its in the manual !
R
Test your alarm to see if it sounds and flashes its hazard lights when its triggerred.
Lock yourself inside the car, stay still for 60 seconds then open a door/s bonnet or boot.
If the alarm does sound, follow the sound to locate the siren, there should be a plug in the rear of the siren, unplug it, if the siren then sounds like an asthmatic cat then there is a good chance that your alarm siren could be coming to the end of its life.
Dec
