Hi All,
My car sat with the dealership for 2 months and after received the car back I got a "auxiliary battery malfunction mercedes" on the dash and so I thought maybe it needed charging or replacing. I did some check to see the condition of the battery and the volt meter is showing a good state of charge of 12.6V and I also hooked it up on the charger which then gave a Full Charge reading. I plug the car onto a rearder and it has given
C073300, "Read fault memory of control module. "N10 ( SAM Control Module)"
B1E211B, "The buffer battery has a malfunction. The limit value for resistance has been exceeeded."
I've wire brushed the contacts but the same error keeps coming back.
My question is, is the voltage reading not a good indicator to wether the battery is still in a good state of health, or should I be check something else within the car?
Many thanks.
Many thanks.
