C240 Sport
Can anybody tell me what exactly does the auxiiary battery do on a cls 320 2006
That depends on driving style/journeys and if the battery is taken good care with a decent battery charger. My car is manufactured in 2011 and the Aux Battery was replaced for the first time last year (Oct 2018). The previous owner didn't bother with charging the aux battery so it it oesn't sound that often to me to have the battery replaced once in 7 years.Goes flat then has to be replaced frequently from what I hear![]()
sign of the times I guess.Many modern "garage queen" models come from the factory with CTEK style charge connectors
I do not think any modern vehicle should rely on an external charger unless laid up for a very very long time , in which case it would be better to remove the battery from the vehicle (not always practical I know) The car should be the charger, no matter how short the journey. A car should IMHO be able to start itself on a (previously) fully charged battery after a 8 weeks of being dormant in any weather.
Sadly this is not the case with ECO Start/Stop which typically includes Smart Charging. Smart Charging only charges the battery to 80% upon which the charging is disabled unless the engine is on over run. In my experience, for short journeys that includes frequent starts/stops, the battery often ends up with a charge well below 80%. This, coupled with a dash cam supporting parking mode will reduce the battery life unless topped up frequently. Putting the AGM battery for a vehicle with ECO Start/Stop seems to the general recommendation from various discussions in various forums. Each to their own of course - if one has never suffered a battery with a premature life, there is no need for one to put the battery on a charger. On the other hand, if one's battery lasted only 2 to 3 years, it is reasonable for one take some additional precaution I suppose.[/QUOT
That is one of the reasons the whole 'eco' stop/start thing is a load of $hit
No one will ever convince me that stop/starting an internal combustion engine 100 times a day is good for anything. let alone the environment.
No. not 'each to their own' anyone who knows anything about machinery/aircraft/cars/trains/power stations understands that once you have overcome the wearing forces of cold and inertia to get the thing started the VERY worst thing you can do is to stop it only to start it up again for no good reason.
I have no evidence of this that I can show you but my own experience would lead me to believe that the very first time stop/start 'technology' was suggested to engine design engineers they would have all looked at each other in the meeting and thought " it's not April the 1st ..is it ?"..'which nob head thought this was a good idea for engine/battery longevity' ?
They would have been forced to go along with it to 'save' the planet and soon would realise that their jobs were safe chasing a state sanctioned impossible dream, so they went along with it.
Even the Lycra lout 'holier than thou' vegan Xtension R city center cyclist knows that going through a red light is more energy efficient than stopping at it for no good reason.
Are you suggesting an E class MB 'Munich' taxi will not stop/start 100 times during it's working day ? Years ago when this stuff was new I picked up a hire car (Citroen I think) from CDG in Paris, unfortunately for me I had to drive into (and out of ) the city. I am sure it switched itself on and off at least that amount of times during that particular nightmare.100 times a day?.
If the traffic was that bad on my commute i would find an alternate means of transport
Or is that a made up statistic to support your own preconceived view?
Batteries are generally regarded as consumable systems are coded to check a wide range of parameters which need to be satisfied in ordered for stop/stop to operate, as evidenced by the varying nature of operation. An engineer friend tells me cars are designed with an economic life of 7-10 years.
If the implementation of stop start tech means i can continue to enjoy the use of ice power for a few more years, and delay the inevitable switch to alternatives such as electric or hydrogen, bring it on i say.
Wong, Absolutely agree, I would probably do the same, the issue I have is that the system defaults to ON which and can be dangerous at junctions if the driver has forgotten to press the off button. How do you sit for long periods in extremely hot conditions with no air con.
