Una
Hello everyone.
I have a question concerning my 2005 SLK 200. My battery keeps going flat. It's a new battery, so I took it back to the store where I bought it and they checked and said it was in perfect condition.
If I could explain, I am a new widow who hasn't got a clue about cars. My son put the battery on charge and everything was fine for a while. The battery went flat on me on three other occasions, the alarm would go off and drain the battery. I took it to the garage when small electrical things started to go wrong. It turned out that the seal in the driver's door had completely broken down and water had got into the electrics under the driver's seat. That job was costly, but after having the door seal fixed, the electrics dried out, everything was fine again. Until last Wednesday, when it rained. The battery was flat again.
It seems, on reading posts on here, that it's a common fault for batteries to go flat.
Where do I go from here? Should I buy a battery tester thingy and take out the fuses one by one to find what's draining it?
Also, I don't go on long journeys and usually only use the car once or twice a week. Short trips to the shops. Is that where I'm going wrong?
Any help or advice would be greatly appreciated. Thank you in anticipation.
