Hello guys
I hope and wish everyone is keeping safe in such Covid times.
Recently I have noticed some Battery related issue so thought I would take some pointers and advice from here.
The car is nearly 13yr old.
Somewhere in January 2020 the alternator was replaced as the main battery went dead and couldn't charge.
Then in next month Feb 2020 the original Merc battery was replaced with Varta battery (4 yr warranty) as it could not hold charge for more then 8-9 days.
Now as like quite many people I also work from home and doesn't need to go out for quite even 10 days.
Just recently after the gap of 10 days when I started the car, the sound of crank was quite slow and it felt like the battery has not held enough charge, though the car started on first time. I then ran the car for quite 30 min so making sure the battery is charged properly, all consecutive starts on the same and following days were good powerful enough, again drove for next 5 days.
Then again car was left for nearly 9-10 days and when started the car, the sound of the crank was slow but it started first time.
Like others, I have driven this car so much on regular basis, I know the sound of a powerful crank - the first crank. But the thing is even though the car starts on first try, from the last 2 incidents, it clearly shows the symptoms as the battery is not holding good power and shows the weak start.
My other friends who has got Merc E220 when they leave their car for even 15 days, and on the first start, the crank is still good, even though their battery was not original and quite few years old.
Before I get into any major issue/repair work I thought I would take some suggestions. pointer to check this.
Should the new battery be like this - after quite good runs, leaving it for 10 days without run and then the first crank would b slow?
Also, just for the info, in case when I think of something draining the power, there are no accessories connected to it apart from the Stereo (not original but single din - Alpine) which is connected as per standard connections and the dashcam - which would turn ON only when ignition is ON.
I see no other lights ON when I leave the car (not even in the night time).
I appreciate your help.
Forgot to mention, checking the battery voltage in the morning, it does show 12.1V and I also checked it through the Display Menu that once the car is started, the alternator does provide 14.1V
