BlueTEC G350 G-Class Announced
KillerHERTZ
Administrator
Staff member
Cambs
SL63 AMG
Mercedes-Benz G 350 BlueTEC Announced
350 BlueTEC with state-of-the-art emission-control technology: A true classic
Impressive output and low emissions
Exceptionally robust design, outstanding off-road capability
The latest version of the classic Mercedes-Benz G-Class off-roader, now in its 31st year, features state-of-the-art BlueTEC technology. BlueTEC is a Mercedes-Benz-developed technology designed to reduce diesel vehicle emissions, especially nitrogen oxide (NOx) emissions. The BlueTEC version of the G-Class uses AdBlue®, an aqueous urea solution which is injected into the exhaust-gas stream. This process releases ammonia, which converts up to 80 percent of the nitrogen oxides into harmless nitrogen and water by a process of reduction in the downstream SCR catalytic converter. Since the G-Class is often used in remote areas of the world - one of its main purposes - the engineers have simplified matters by integrating the AdBlue® filler cap in the vehicle's outside tank recess. One full tank of AdBlue® is good for around 12,000 kilometres.
The V6 diesel engine in the G 350 BlueTEC develops 155 kW (210 hp) at 3400 rpm and has a torque of 540 Nm between 1600 and 2400 rpm. This model therefore produces substantially fewer emissions than the previous G 350 CDI model - undercutting the limits of the EU5 standard and, in particular, reducing NOx emissions by around 50 % - yet still delivers comparable performance.
A full range: the current G-Class
The "G" family currently has three body variants - short-wheelbase Station Wagon, long-wheelbase Station Wagon and Convertible - which can be combined with either the new BlueTEC engine, as described, or a powerful 5.5?litre V8 petrol engine developing 285 kW (388 hp) with a torque of 530 Nm. The flagship G 55 AMG model - available only as a four-door, long-wheelbase Station Wagon - is powered by a V8 supercharged engine developing 373 kW (507 hp) with an impressive peak torque of 700 Nm.
The evergreen Mercedes-Benz off-roader continues to offer a superior synthesis of high-performance drive and dynamic handling control systems. The standard specification includes the electronically controlled traction system 4ETS, the Electronic Stability Program ESP® and three differential locks selectable at the push of a button, alongside the permanent all-wheel drive with off-road ratio and the 7G-TRONIC seven-speed automatic transmission.
