Boost control valve
Pricey18
England
A200d
Can anyone please tell me whereabouts the boost control valve is on a A200d 2014 2.1 140bhp thanks I can’t find it I can see the sensor but not the valve cheers
its slightly difficult to say as you are using some universal code reader but boost control is always on turbo, then OM651 bypass is separate valve if its two stage, plus there is throttle flap etc... what problems you have, what fault codes?
First is p2279 inlet air circuit lack of air in Linley circuit leak
Permenany
second p200a boost control valve
Bank 1 range performance
Signal to low
It’s not my reader
Totally crazy descriptions... Try check out all boost lines no splits or leaks. Boost faults can be anywhere on boost lines, including EGR, or it can be pressure sensor fault. Extra knowledge needed when playing these humblemumble infos, live data will hopefully tell something. SDS would have individual component tests and precise teaxt of fault codes.
Cheers I well have a good look over it tomorrow I did think it could of been pressure sensor as faults was wiped and haven’t come back on yet thanks mersum
