Hi all,
I’ve recently replaced the spark plugs in my 2006 CLK 500, I’ll attach some pictures below but they are all quite dry and brown. Is this normal? Or could this be lean fuelling. I should add two of the plugs are only 2000 miles old (cylinder 3) and are being replaced due to wanting to replace the others which were not done. However even the new ones looked just as old.
if so what could cause this. I should add the car does have a rough idle and misfires under load / harsh acceleration. It always says cylinder 3 misfire however cylinder 3 had brand new plugs, coil pack and leads to no avail which makes me think the car is throwing cylinder 3 when it is in fact a broader issue.
Any help would be appreciated and here are the pics below. Thank you
