C215 CL500 glove box unable to open.
tonyhtb
W124 E320 ESTATE
Hi did find a thread but cannot find it. Can someone enlighten me on the fix. PSE problems but have the car booked in to fix actuators and pump next week.
Make sure it isn’t locked unlock the car with the remote, it will lock itself after a while. If that isn’t the issue make sure there isn’t anything stuck in the join of the door. If there is and you can remove it get it out if not then grab the handle ‘switch’ grip push in hard and pull back gently a few times, worked for me a couple of times.
