i need help diagnosing a 2005 C230 Kompressor (M271 Engine) that is hard to start and will not idle. It runs smooth with reasonable power when the RPMs are over 1500. It dies if you let it idle when cold. Will idle but very rough when warm. Starts easy after a stater fluid spray.
It is throwing codes P0171 (lien trim adjust limit) and P0300 (misfire) all the time and occasional throwing codes P0304 (RPM) and P0444 (Evap purge circuit open).
Compression test results:
dry: 95-100 PSI all cylinders
wet: 110-115 PSI all cylinders
No obvious vacuum leak. Plan to do smoke test tomorrow.
Just purchased the car, so do not know the history. 140,000 miles. The body/interior indicates the car was well taken care of. I seems like a large vacuum leak causing fault codes. I'm at a loss to explain why it runs so good with the low compression.
any help is greatly appreciated.
- Roger
- Roger
