Borris1954
- Feb 4, 2013
- Location
- South Bucks
- S204 C 250 CGI BlueEFFICIENCY, R170 SLK 230, B 180d AMG Line
A siren activated this morning whilst my car was on the drive. I was working nearby in my garage and looked out to see no one near the car and no lights flashing on either my C Class or my wife's B Class and I initially thought it was a neighbours car. On closer inspection the sound was coming from my 2009 C250 Cgi yet the alarm did not appear to have been triggered. Using the remote to unlock the car did not stop the siren and neither did starting the car. Apart from the noise the car was normal. I shut the car off and locked it again with the remote. The siren continued when I unlocked the car again. I started the car and ran the engine a bit longer and after about 30 to 45 seconds the siren stopped. All now appears normal and when I connected SDS there are no fault codes stored or current associated with the alarm.
I am strongly suspecting I need a new alarm siren - it's original as far as I know so due replacement as its internal battery is probably at the end of its useful life. I am thinking that for whatever reason the siren thought it had been tampered with and only after running the engine for a while did it change its mind.
But before I spend the dosh has anyone had a similar experience and/or got any advice of other things to check? I see EPC lists a the siren connector as an available part so I will definitely take a look at that for corrosion as a possible cause.
