Had this fault and a few other related faults. Had a quick look with icarsoft, at sensor B19/11. I'm pretty sure this is correct sensor, but please correct me if I'm wrong. The reading first thing in the morning was 352oC, when the car was stone cold and had not been started. I therefore took it to local garage and asked them to check and repair. They have replaced an O2 sensor, which looks to me like a Lambda sensor, rather than a Temperature Sensor. Didn't get a mile from garage and MIL back on.
The sensor they changed looks in approximately the right location ( drivers side, just below the ECU, upstream from Cat). I plugged back in when car was cold, before starting and this time temperature reading 850oC.
Can anyone confirm a few things:
Thanks in advance for any assistance offered.
PS: I'm no mechanic
- Is B19/11 the correct sensor (Exhaust Gas Temperature 1, Bank 1)
- Does it sound like they have changed correct sensor, as I thought it would have been 2 wire sensor and not 5
- Correct location
PS: I'm no mechanic
