I have 2012 w204 C250 which I think the battery is on it's way out but not sure which one.
Since March's lock-down, i was hardly using the car but when starting the car after a week or two of no use it was starting fine. As we came out of lockdown I recalled i have not seen the start/stop function throughout the whole of lockdown and thought it might just be down to short drives to supermarket the car didnt hit the requirement to stop/start.
It went in for a B service at Mercedes Brooklands in late July and no faults, only issue with the a screw holding the engine tray which they fixed as complimentary.
In October the vehicle went into limp mode and needed the intake boost pipe (forgive me if this isn't the correct technical name) changed and throttle valve seal replaced. When i picked it up from the garage, i noticed start/stop indicate was green and functioning again.
Vehicle has been in use twice a week since the most recently lock-down but last week in the morning it struggled for a split second to start and did the same this morning. Start/Stop indicator stays yellow and doesn't go green at all. In addition to this, the brake hold did not work but on the return trip, brake hold had returned.
Am i correct to assume its the Aux battery which needs replacing and located next to spare tyre in the boot. If so please can some recommend which replacement to get?
Any help will be greatly appreciated and thank you in advance.
