noobydoouk
Hi everyone - new to the group so please be gentle.
I’ve recently bought a 2017 C43 estate and after successfully mapping my old C220d I decided to do the same thing. I went with Celtic tuning for a stage 1 remap to start with and, as far as performance goes I was very impressed indeed with both the throttle response and overall performance gains.
After a couple of weeks of getting used to it I started to play faster and in manual mode where I noticed a significant issue…… here goes!
In Sport+ & manual, I’d accelerate hard through the gears and off she goes but when I get into 5th at around 4100rpm / 94mph the engine would just lose power and not go any higher than that. Change into 6th and it would do the same i.e. sit at around 3600rpm but go no higher. Initially it would only do it in Sport+ & manual but as time went on it started doing it in auto too, albeit not as bad. Then even more recently it started doing it in Sport & manual but not auto. All other engine modes both manual and auto were unaffected.
To try to remedy this I spoke to Celtic and we tried the following:
Take the map off and reload into the car
Try in different weather conditions and different phases of driving e.g. after a short run, medium run, long run etc and nothing changed.
Tried settings in individual mode.
None of this worked and it continued to do it so to see if the car had an issue I had the map taken off today and everything runs fine in all modes and settings.
Celtic said it’s a well used map and they’ve never had an issue with it. I’ve also been consistent with using super unleaded fuel since buying it in September last year so can’t be that.
Anyone come across this or know what it could be?
Thanks in advance, Steve.
