C63 w204 estate 19” 245 265 tyre pressures warm/cold
Theador
C63 BiTurbo Estate W205
I’ve gone one profile up on the tyres 245 35 and 265 30 r19” on the C63 w204 estate. Should I keep the pressures the same 41/42psi and is that a warm or cold reading
Tyre pressures on the fiuel filler flap and in the manual are a guide only and you should adjust based upon wear.
The guidance doesn’t change with such a small change to tyre size, so go with the guidance and adjust based upon wear:
Always measure tyre pressures cold.
