SLSWE
Hey all looking for advice here,
I've noticing that my water temperature is fluctuating and are wondering if this is common or something I should have looked at. I am fully aware that engine oil temperature fluctuates between 100-120+ C depending on driving style etc, however the water is not mentioned too often.
When driving on the highway today in 60 - 80mph the water temperature struggles to stay on 92C which I understand is the standard temp. Today it went down to 84C and then moved back up to 92C and then down again to 86C or so and then keeps fluctuating but rarely sits at 92C. When I then left the highway it went to 92C and then increased to 94C when I drove on roads around 25MPH to my garage.
Is this normal and does anyone else experience the same? Oil temp is around 105C and I guess that is the most important temperature so it's not overheating or being to cold wearing the engine.
If not, any ideas what this are symptoms of and what that needs to be replaced to solve it? I'm thinking it is either the thermostat or water pump if this is not as it should be. When walking from the garage I was not sure if the radiator fan (or what fan it is) actually sounded before I turned the engine off.
