Can I use W203 rims on my W209?
Gollom
Hardcore MB Enthusiast
Preston, Lancs
S204 C220CDi Sport ED125 (Mr) Kia Picanto Domino 1.1 (Mrs)
Both cars have the same staggered tyre set-up and are of the same year
Mercedes C Class W203 00 - 07 16 Inch Alloy Wheels staggered 205 55 16 5 x112pcd.
2 x 205 55 16 tyres
2 x 215 55 16 inch rear tyres
Anybody? Cheers
They’re fundamentally the same car so there ought not be any problems. It’s the offset measurement (“ET” followed by a number) which is what will likely cause any problems upon fitting.
Do you know the offset of your current and target wheels? If not can you post a photo as we maybe able to look up the offset based upon the photo.
Thanks. Pretty sure they are both 37
If they’re the same offset then they should fit a treat. Are the tyres the same size as you have on now?
Rears are 215/50 - my tyres are 225/55 so from what I have read they will be fine apart from a very small speedo inaccuracy
Do you know front/rear tyre sizes for both sets of wheels?
I'll be using the existing front tyres (205/55) from the CLK. Got it wrong earlier - CLK existing rears are 225/50 and I be putting 215/55 on which as said earlier I think are fine? (apart from minor speedo inaccuracy)
Many thanks
I think you might find the 203 is on 12mm bolts, while later models went up to 14,mm.
Certainly worth checking out.
12MM ON MY (54) CLK
Only thing to watch out with the clk is the fat stickie out calipers. Some low brow OEM w203 wheels do not clear them
