stevegbr
i need to know if i have to remove the centre console as a unit, or can i just change the armrest lid as it as broken away.
mercedes w203 avantgarde se a 1.8 2007
A nightmare !Getting the armrest lid off is a real faff, as is getting the replacement on - - - - - just perseverance and lots of bad language.
Ian.
This is just what makes the forum fantastic. Gives useful information with good banter (and a wife in my particular case.... )Hi folks - a bit late to reply but I've been ill. I can add some, hopefully, useful advice on the armrest lid refitting procedure. I spent time researching it (doesnt seem to be 'officially' covered anywhere) & have put together a pdf document that explains the procedure of re-fitting the lid after it comes off. It's attached, hope it helps.
is there a way of getting the right one for your car, as there a lot that looks the same, but some seem to fit different, hope this makes sense.Hi folks - a bit late to reply but I've been ill. I can add some, hopefully, useful advice on the armrest lid refitting procedure. I spent time researching it (doesnt seem to be 'officially' covered anywhere) & have put together a pdf document that explains the procedure of re-fitting the lid after it comes off. It's attached, hope it helps.
Hi stevegbr, I have based my pdf on my own car (W203, 2005) and I have assumed the saloon is not much different. Again, your car is a few years newer (an age in the designer world) so it may have been changed on later models. I can only suggest using Google as I did - maybe you'll get lucky.is there a way of getting the right one for your car, as there a lot that looks the same, but some seem to fit different, hope this makes sense.
