Apr 7, 2019 #1 R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi Hello, I've been trying to remove the two pipes at the bottom of the ac condenser. The pipes will not come apart. I have unscrewed the middle bolt. Any suggestions?
Apr 7, 2019 #2 Trickythemerc MB Enthusiast SUPPORTER Joined Feb 1, 2015 Messages 4,337 Location South Manchester Car CLK 220 CDI Sport 2009 They should just pull out off the O-Rings but can get pretty well stuck in there, it's normally the bolt that is a sod to get out.
Apr 7, 2019 #3 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi Any other ideas on how I can remove the pipes?
Apr 7, 2019 #4 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi The plate holding the pipes in isnt moving at all, tried greasing too
Apr 7, 2019 #5 whitenemesis MB Club Veteran SUPPORTER Joined May 7, 2007 Messages 19,945 Car Lexus RX450h F-Sport with Takumi Pack 2020 Take the car to a good independent ..
Apr 7, 2019 #6 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi I would but I've taken things off and it's just this damn pipe that doesnt want to come kff
Apr 7, 2019 #7 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi I would but I've taken things off and it's just this damn pipe that doesnt want to come off
Apr 7, 2019 #8 whitenemesis MB Club Veteran SUPPORTER Joined May 7, 2007 Messages 19,945 Car Lexus RX450h F-Sport with Takumi Pack 2020 Apply a little gentle heat?
Apr 7, 2019 #9 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi Just tried again before I was going to pack it up, plate moved a little. Will update in the next 30 min
Apr 7, 2019 #10 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi Okay, thankfully the two pipes came away after all that greasing and hammering. Thank you guys for posting your suggestions.
Apr 7, 2019 #11 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi I am having troubling getting the condenser out, what do I need to remove ?
Apr 7, 2019 #12 Trickythemerc MB Enthusiast SUPPORTER Joined Feb 1, 2015 Messages 4,337 Location South Manchester Car CLK 220 CDI Sport 2009 Either the front bumper or the slam panel. I took the slam panel off when I did mine.
Apr 7, 2019 #13 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi There is a pipe that's on the bottom left of the condenser, inside the hole is a gearbox connector hose. That has to be removed ??
Apr 7, 2019 #14 OP OP R Remix Member Joined Jan 9, 2019 Messages 44 Location Cheshire Car Clk 320 csi Is your gearbox pipe connected through the condenser ?
