Hi All,
New to the forum,
I recently bought a clk 55 AMG 76000 miles
Checked service history and as a result changed the plugs/leads/original fitted Mercedes parts/k and N air filters,
The old ones were solidly blocked, and gearbox oil service, 2 litres in it instead of 4
Car seemed to be running fine from my limited experience but now runs/sounds even better,
Only problem I have is in low gear seems to stutter/hunt until drops a gear then flies,
It doesn’t happen any other time, I.e during acceleration, just at low speed,
It has improved since I changed the parts I mentioned in that it seems to select the lower gear a few seconds after the issue occurs, it may sound silly but not being a mechanic I thought it may be a characteristic but seems unlikely,
Apart from that the car runs great if a little juicy, it was showing 11 mpg at one point and I don’t know if it’s my exhuberence with the pedal, looking around the internet I was thinking could be the fuel pump/filter,
Any clues would be helpful
New to the forum,
