My CLK430's gearbox has decided to stop shifting gear properly. I can select drive and reverse, but there's a bit of a jolt when selecting, and then it seems to be stuck in 1st and I can't manually select any gears either. I assume this is some kind of 'limp home mode'?
I first noticed it last week, and after a switch off / re-start it was back to normal, but this weekend it was doing the same again so needs further investigation. I've done some googling and the first step is to check the oil level. Are the cheapo dipsticks up to the job or do I need to stick with a known brand? Also I've seen some guides say the car should drive or reverse when checking, others say neutral. Is there a definitive guide on how to do this properly?
