Hi Folks,
Newbie looking for some help please with my 2002 CLK430 convertible (722.6 5 speed auto) that's stuck in limp mode. My OBD II scanner returned code "P0715 - Input turbine speed sensor". CEL is also showing. I've searched a lot of threads on this issue and based on the advice have changed the following with Mercedes OEM parts/ fluids:
He re-scanned and it's still throwing up the P0715 code with the following message "P0266 - fault code is stored in the component 'N15/3 (Electronic Transmission Control (ETC/EGS) module)'.(P0715).
Any thoughts on where to go next with this issue would be much appreciated.
- ATF 134 fluid / filter / Conductor plate / 13 Pin connector socket.
