martin_sv
- Jul 2, 2012
- Location
- North Hampshire
- E350cdi Coupe 2012, R230 Sl350 2003 + CLK 320CDi ( will be putting it up for sale)
Hello all,
FInally decided to move from my CLK320 after 6 years of great motoring to its' sucessor the E coupe. Couple of issues to fix and I want to try a hard reset to my comand which is I believe an NTG4.5 ( 2012 carwhich has sd card slot on front of unit). Can anyone tell me if this is safe as I dont fancy losing the installed map?
FYI, the issue I have is that the OBC mpg display runs fine for "from start" but no values display when viewing "from reset" ( just shows zero mpg in the display and the bar chart columns are all also at zero. I'm hoping this is a software glitch as consumption is clearly capable of being measured hence my desire to do the usual " turn it off and then on again" approach.
thanks if you can assist
Martin
Martin
