I have been using a Race Glaze Water Filter for about 3 years now, with a fleet of blue/black cars to deal with its been an absolutely brilliant product. I started with a 7L and now have a 14L.
The benefits are clearly stated above - you simply rinse off the tap water residues at the end of your wash process with a wave of filtered water and walk away. No need to dry. make sure you spray inside wing mirrors and around boot lips (places where water trickles out later on). Even in bright sunshine, no water marks.
The key thing is to use this water sparingly - an average car can easily be walked round in less than a minute. Allow more for S-Class etc, but a hose on half pressure will minimise usage. Don't use a P/W - uses too much water and doesn't get that wave effect.
There is some science to the shape of vessels which is clearly explained on here - its all about aspect ratio (best is tall and thin, not short and squat). Its not purely about capacity of the vessel. Unfortunately the 11L shape vessel isn't very efficient so it will cost you more in resin refills over the long run than a more efficient unit.
Race Glaze Water Filter 14 Litre RG-Filter-14L
