Driver’s side brake light not working
eyezcar
PETERBOROUGH
vito 111 cdi
Hi all I'm have a mare with my driver’s side brake light. fitted new bulbs, tested on the passenger side which works, getting the multi meter out but not a sparks need to know which pins to check with the meter.
You likely have split wiring in the loom at the boot hinge. A very common fault with some cars.
Unlikeley ,,.if one side is working because it gets power from the same place, i recon fault in the sam modual. Try a better quality bulb first like Bosch. Or better still a Mercedes bulb
