I suddenly have an orange engine management light on the dash and the car has lost performance. It will start ok and run as long as I poodle about slowly. However when I put my foot down on the accelerator the engine doesn't pick up, and sometimes the gearbox seems to go into some limp home mode and I have to turn the ignition off and on again to reset it. I called the RAC who pluged it into their diagnostic laptop and gave me the below read out.
Can anyone offer advice on what to check for please ?
I am about to remove the air pipes going from the air filters to the turbo to make sure the turbo spins ok and there are no obvious blockages, but I have little knowledge (and little money at the moment) so Im only likely to spot something very obviously wrong. Any help \ advice would be very much appreciated. thanks Kev
Diagnostic Codes
RAC DIAGNOSTIC SYSTEM
System Type: ENGINE SYSTEM TEST/VALUES
Name: 642.920 - -->05/05 - CR3_UP - 3.0L - 165 (224)
642.920 - -->09/03 - CR3 - 3.2L - 165 (224)
642.920 - 10/03--> - CR3_UP - 3.2L - 165 (224)
642.920 - CR3_UP - 3.2L - 165 (224)
642.920 - CR3 - 3.2L - 165 (224)
DTC: 2510,Right charge pressure positioner
DTC: 2513,Inlet port shutoff; positioner signals fault
DTC: 2230,Transmission Control: ETC fault
DTC: 229711,unknown
DTC: 2527,Left EGR positioner, signal line is interrupted
Name: 642.920 - 06/05--> - CR4 - 3.0L - 165 (224)
642.920 - CR4 - 3.0L - 165 (224)
DTC: 2510,Charge pressure positioner
DTC: 2297,Transmission control ETC; short circuit to positive
System Type: ENGINE
DTC: P0244,Supercharger (SC) bypass valve A - range/performance problem
Turbocharger (TC) wastegate regulating valve A - range/performance problem
DTC: P2015,Intake manifold air control actuator position sensor/switch , bank 1 - range/performance
problem
Diagnostic Codes
DTC: 229711,unknown
System Type: ENGINE
problem
