DukesE63s
I don’t usually post on forums but I thought this one was worth posting as it saved me thousands. I had the “electronic rear diff lock inoperative” message come up on my dash, I put the car into drift mode but the diff was staying open. Only 1 wheel was spinning. Wanting to do things properly I took the car to Mercedes’ they said the diff has failed it will cost £4700 inc labour etc, decided to take the car to a mechanic friend of mine to check it before replacing. He pulled the diff off and opened it up to find the DC motor had failed causing the diff lock sprocket to jump out of place. I replaced the DC motor which was £290 and realigned the sprocket. Put new seals on whilst it was off and put it back on the car. He cleared the fault on the dash which wouldn’t clear previously and hey presto she’s good to go again. I did a lot of forum searching for the diff lock problem & a lot of people saying the diff is scrap so I just wanted to put this here in case it can save someone else a fortune. Cheers
