capella313
Hi All,
Had car recently serviced and hooked up the computer just randomly.
Found this error codes that will not go away after clearing:
B210F-00
Circuit 30 Has A Maifunction. There Is A General Failure, - Stored.
P0635-4B
Electric Power Steering Has A Malfunction. There Is A Fault Due To Over Temperature,
8210D-16
The Power Supply Is Too Low. The limit value for electrical voltage has not been attained
J0416-00
implausible Data Were Received From Control Unit Traction System. There Is A General Failure.
P.S No problems with the car at all.. However, there was times when i thought the wheel felt a bit heavy. Also, changed both aux and battery this year.
Hope anyone could share same experience or advice would be nice. Thanks
B210F-00
P0635-4B
8210D-16
J0416-00
