Engine management light
jamiebee89
Leicester uk
b class 220D amg line
Good evening all
I'm new to the forum and have owned my 2017 b class for around 6 months, and has been good for 6 months but now my first issue has arrived
I had it plugged in for diagnostics with a local garage to which they came back with exhaust flap fault, I removed the actuator and check3d the flap which appears to be nice and free, so replaced the actuator, but unfortunately it has made no difference
The car is in like a limp mode and won't go over 3000brevs I had it rescanned after fitting the new part
To which I got told the dpf is now blocking/blocked
And a fault code of 13C700
can anyone help please I'm at my whits end
Thank you in advance
It might be the dpf pressure sensor, common fault on the Merc engines, not so sure on the Renault engines though, depends which one you have.
There are mobile on car , dpf cleaning services available, might be worth having a search for one in your area.
