Factory reset
Darek19
Uk
Mercedes e220 4-matic 2019
Hi all.
I have some problems with Mbux in mercedes e220 2019,clocks on dashboard keeps changing to km and design keeps changing to classic from sport. I done software reset trough engineering menu.
Now Im missing Reverse camera, no sensors, half of settings dissappear, no settings for ambient lightning, basically more than half of settings dissappear.
Any help pls.
Hi all.
Any help pls.
I would take it to the main dealer. You wouldn’t my be the first person to brick a car hi-fi using the engineering menu to fix an issue. It sounds like the reset has already made things worse, so I would avoid the temptation to tinker. Good luck getting it sorted 👍🏻
Hi all.
Any help pls.
Did you managed to fix your problem? Done the same thing and having the same problems now.
You are likely to need a software update on the whole system. Dealers and good independent specialists can do that for you.
Spoke with all the dealers from Glasgow and they said need a full diagnostic and then need to do the coding the unit.
