Just for the collective
I have an ongoing issue with my E320Cdi (210226 613 engine) where by it will faulter around the 4000rpm mark. If you push it gently to that level then it's like a very major mis-fire, but if you floor it to that point then the point will drop off so abruptly that it's like you have hit a stationary object at slow speed.
the code that get logged is P1354 - Cam/Crank synchronisation inplausable.
when I put if first on a code reader it would get logged at start up.
I even took it into a dealers and they couldn't find anything conclusive as to the cause of the error.
This week I managed to get it over to a mates of mine, who has several different workshop code readers, and now the code only gets loggerd when hitting the 4000rpm area. I can only put this down to changing the chain tensioner.
My mate put a call into a guy, that is very well respected within the diagnostics area, and he came back with that it was caused by the VVT (yes I know what this means) not working.
After a bit of confirmation, I know that this engine does not have VVT, therefore the info I was given was tosh!
Therefore I was asking the question about the flaps to understand what their role within the engine is.
I had a long chat with the service manager at my local dealers yesterday, and they are not aware of any issues with timing chains on the CDi range of engines and could not put 'hand on heart' and say that replacing the chain will resolve my problem.
The price from them was around £700 but did talk about me doing the job, but I did hint about not having the correct chain riveter.
I do think that it could be the chain as replacing the tensioner has changed when the fault code is logged.
