Fuel Level Multiple Senders? - C220 W204
karldonteljames
Kent
C220 AMG Sport ED Premium + CDI Auto
Afternoon All,
I'm currently looking at purchasing a C220 CDI on Thursday. I want to be able to track the fuel level remotely. I have a solution for doing this, but the device I want to use needs to be connected to the fuel sender and then I need to take multiple measurements and enter those readings into the software so it can calculate the fuel/voltage levels. The issue I'm having is that it looks like there are multiple fuel senders.
Any advice on how to achieve this, please?
Sorry, I'm not sure if this is engine or electrical
Thanks in advance.
it might be worth checking to see if you can do it via the Mercedes Me app.
Pretty sure this was possible on my 2017 slc.
I could do it on my 2019 c class through the app.
  • Like
Reactions: Ted
The car i'm looking to buy is a 2015, so not sure if it has any of the more modern stuff. I did post about some buying advice, but the post said it needs to be approved and still hasn't yet for some reason. I want to be able to track things like long term fuel efficiency, and pull this data in Home Assistant ideally. :D
Massive Nerd here.
Massive Nerd here.
Even if your model doesn't have this facility via the app, you can still do this on your dashboard.
There are lots of sub menu's for you to use, and play with!
Good luck with it.
thanks. I'm looking to integrate this into a dashboard on my phone / laptop with a vehicle tracker, rather than inside the car on the dashboard.
I'll also be able to use this for automations, notifications, and general long term data collection.
