I have a 2007 gl320 when left parked overnight or for a few hours the front right corner will lower down to the bumpstop but as soon as you start the car it rises back up and is fine all day,
I have replaced the front right airbag and airline but the problem is still there. something that bothers me is if i disconnect the air hose from the pump to the Valve block the hose hisses and
the front right lowers itself down. Could the valve block have an internal fault where the front right airline valve port is leaking into the compressor valve port? i have noticed they are next to one another.
Just after some advice before i order a valve block
