Scrote
Hello, after the success of my DAB retrofit, I am bored so now looking to DIY this, but I have nothing much to go on, so looking for info, hopefully somebody knows something and can answer some of these questions.. please..
1st of all is it even possible with audio 20 6 disc..
I presume the standard system drives all the units from the head unit, with no seperate amp...?
and I'm 99% sure the HK system has an amp with MOST connection, so I presume there is a different set of wires required which go from the amp to the doors etc. + there's a subwoofer.. anybody know if estate subwoofer same as saloon? and does this sub receive audio from the MOST, or the HK amp or where? are the amp and subwoofer two separate options in the coding.
Anyway I will go see some breakers and try to get the parts but I think it's going to take some time.
Seen various listings of parts on ebay but I'd rather get some wiring or at least plugs included..
Somebody else must have done this? tried a search but found nothing. I know the command.co.uk guys have but I'm talking DIYers as I wouldn't expect pros to reveal their secrets.
Also be nice to know the correct positions on the MOST bus, I currently have DAB positon1, UCI position2 as per OE. Turns out we have an Autel at work I can borrow.
Am I even barking up the right tree? help!
Cheers, Stu
Cheers, Stu
