Indicator problems
kennyc
Hi, still got this problem and it's driving me mad, when I indicate left my display flashes fast but indicators looks normal. But when I drive and do the same it does all the same problems but says on dash front left light as fault, again all lights working
Try a new bulb or swapping them over from side to side to see if the fault follows the bulb.
Also check to see if the lights in the mirror are working.
Hi thanks for your reply, mine are LEDs and they are all working
I have a 05 S320CDI and had the same problem but on the right hand side. There was also a problem with my right hand folding mirror. When the mirror problem was investigated it turned out to be two broken wires in the wing mirror loom. When these were repaired the issue with the indicators went away and never returned. I suggest you check the wiring to the wing mirror as it also has an indicator
Thanks for reply, can I just ask was all your indicators flashing with the 2 broken wires
Cheers will have a look there
