Location of Vito W447 Fuel Pump Control Unit
KNU7S
Gloucester
1991 R129 500SL Mercedes, 2002 ML270cdi, 2004 Freelander
Hi all does any one know where it is located on a Vito, i remember on cars is usually near the back seats?
Many thanks
Also does Mercedes still have the online EPC (the one you have to pay for)
Mercedes-Benz Vito W447, the Fuel Pump Control Unit is typically located in the rear of the vehicle, specifically near the fuel tank area. Here are some steps that might help you in locating the Fuel Pump Control Unit:
  1. Check Near the Fuel Tank:
    • Start by examining the rear section of the vehicle, close to where the fuel tank is located.
    • The Fuel Pump Control Unit is often situated near the fuel tank, either mounted on the tank itself or nearby within the surrounding area.
  2. Inspecting the Undercarriage:
    • Sometimes, especially in some vehicle models, the Fuel Pump Control Unit might be accessible from underneath the vehicle.
    • Carefully inspect the underside of the vehicle near the fuel tank, looking for any control units or modules attached to the tank or its vicinity.
  3. Removing Panels or Covers:
    • In certain cases, accessing the Fuel Pump Control Unit might require removing panels or covers in the cargo area or underneath the vehicle.
    • Check for any access panels or covers that may conceal the Fuel Pump Control Unit, and remove them as needed to locate the unit.
  4. Consulting the Service Manual:
    • If you're having trouble locating the Fuel Pump Control Unit, referring to the vehicle's service manual or wiring diagrams specific to your Vito W447 model might provide detailed information about its exact location.
Since the specific placement of the Fuel Pump Control Unit might vary based on the vehicle's configuration and model year, it's recommended to consult the vehicle's service manual or reach out to Mercedes-Benz forums or communities dedicated to Vito W447 discussions for more precise and detailed guidance.
If you're unsure about performing this task yourself, seeking assistance from a qualified mechanic or an authorized Mercedes-Benz service center could be beneficial. They possess the expertise and tools required to efficiently locate and service the Fuel Pump Control Unit in your Vito W447.
EPC
Last update in January 2022, Mercedes-Benz offers an Electronic Parts Catalog (EPC) which provides detailed information about genuine Mercedes-Benz parts, accessories, and their part numbers. The EPC is a comprehensive tool used by dealerships, mechanics, and individuals working on Mercedes-Benz vehicles to identify and order specific parts.
Mercedes-Benz EPC is available online, but access to certain parts of the EPC may require a subscription or payment. Mercedes-Benz typically offers different subscription options based on the level of access required and the duration of use.
It's important to note that the availability and structure of subscription services or fees for the Mercedes-Benz EPC might have changed since then. Mercedes-Benz frequently updates its services and offerings, so it would be advisable to visit the official Mercedes-Benz website or contact a Mercedes-Benz dealership directly to inquire about the current availability, subscription plans, and any associated costs for accessing the EPC online.
Thats how chatgpt answered?
