Murder63
Hi there, first post just thought I’d share a few shots of the work I’ve just finished on my intake manifold to kick start the bottom up engine rebuild I’m about to undertake myself.
Intake had the usual ‘porous’ magnesium corrosion throughout, the sump, throttle plate bracket and the throttle plate itself ( typical ). Managed to clean down, sand blast, prep JB Weld, epoxy prime and metal protect. As for the outside, cleaned, prepped, epoxy primed and then painted.
