RussMarsh
Hi there, I am new to the forum and see there are a lot of helpful people on here. I am looking forward to being a regular contributor and certainly will help if I happen to know something about a problem if I have any experience of it
Background:
My CLS (auto) had done about 50,000 miles and I thought it would be a good idea to give it a gearbox oil change (Before you all jump on me I know now I should have left well alone.. I thought I was doing a GOOD thing!
So I asked a local garage to do the job and I bought the oil and filter kit myself..
Now then - the gearbox when cold seems to slip. You have to sometimes really rev it to get the car moving - I have looked this up and it seems it could be a few things but garages are VERY reluctant to even look at it..
Transmission Slipping Signs
If your transmission slips only when it's cold, then there could be three possible reasons. The first one could be that your engine is low on transmission fluid and could use some more. The reason it works fine once it's warmed up, is because the oil expands with heat. The second reason could be that the fluid has become old and denatured, and needs to be changed. Remember to use only the genuine transmission fluid when you replace it. The third reason could be that the oil has become dirty or contaminated, which again needs to be changed. If it's dirty, then you could also check your filter and replace it, if needed.
ANY help or suggestions would be more than welcome please guys. Also I live near Burnley, Lancashire in the UK so if anybody knows someone who would be at least prepared to take a look then that would be great!
Background:
- The above problem ONLY happens when the car is cold (first drive of the day)
- The gearbox makes no noises and never jumps out of gear or anything like that
- When I arrived at a guy's who said he would look at it the car was warm - he took it out and declared the gearbox was perfect. I had driven on the motorway about 20 miles to get to him and the car flew down the road at 80+ with NO issues at all - I could even shift the gear lever to the left to change it down and to the right to shift it up - no problems at all.
