hi
im new to this forum . I purchased my Vito 115cdi last year after having little vans but decided I needed something a bit bigger I always liked the Vito,s .
my van had/has a few problems I.E aircon not working easy fix . done changed the solenoid works fine .
next problem has been a night mare . van keeps going into limp mode at 3000rpm . took it to an independent Merc garage who plugged it into star to find fault codes . no codes found .
They are still at a loss having tested all the sensors and replaced , checked all hoses on the intercooler no splits etc .
Having done this they took the tank off and cleaned it out .
They checked the coding for each injector etc everything fine . They are now thinking its the electronic actuator on the turbo (even though when ignition is turned off it moves freely .
My Vito is a w639 115 cdi registered 1st feb 2010 .
I really enjoy my Vito and im one of those persons who if it says red line is 6000rpm I want it to be able to do it even though I will probably never need to .
I am looking for some advice if anyone can help a newby out please
cheers kev
cheers kev
