NTHPL888
Hi all,
I’m hoping for some help diagnosing a misfire on idle that goes away as soon as you apply the throttle.
Story goes - I recently put the car in the with the Indy for a service, MOT, check a possible fuel line leak and replace glow plugs. The car ran sweets as a nut beforehand although slightly down on power, perhaps due to minor fuel seepage.
Indy snapped a glow plug and couldn’t remove, called in a specialist to remove but that didn’t work and they had to remove the Head to remove the snapped glow plug.
Also had to replace the fuel pump, EGR valve and one fuel injector.
I got the car back and it’s got a misfire on idle, cars shakes all over the place but as soon as you apply the throttle it smooths out and drives fine, slow down and get near 1000rpm and it starts to shudder again.
Low compression has been identified, but all cylinders are fairly equal around 280psi.
Indy thinks it needs a full engine rebuild but as it was fine beforehand I’m unconvinced.
Any help or suggestions as to the cause of the misfire would be greatly appreciated - it’s taken a couple of months to get to this stage!
Thanks in advance.
Thanks in advance.
