curlyearly
Have an intermittent engine problem with my fathers 2003 ML2003. The specialist mechanic says he search would beneift from a "Engine ECU Pin print out", think I remembered it right. Can anyone help or point me in the right direction.
For reference the fault is of intermittent nature and leads to lumpy running during tick over and medium revs. Never really rev it hard so can't comment about higher revs.
When attached to a computer the faults fluctuate between; Coils (these have been changed around and the fault always stay in the same place - in this case the off side bank). Also ignition and lambda sensors. Have had three lambda sensors.
All feedback gratefully received. Again, my the Engine ECU Pin Print Out if anyone can help.
Cheers all
Cheers all
